I just bought a 1992 Lumina without a motor for $150.00. My question is since I'm in search for a motor, what is the highest year car I can get one out of without having to change anything major.
Newbie 3.1 Question???
sorry, i wasnt paying attention to the topic name.
anyways, you should be able to use any 3.1l from 90-95, it will be a direct bolt in. however, you could do a 3100 or 3400 swap for a big hp increase. it would require custom mounts (i think, im not 100% on the luminas) and some other mods, but could be done.
hmm, thats weird. i thought they ended production in 95. but even then, i have a friend who has a 96 corsica with a gen 2 3.1l. i checked the vin number out, and it was deffinitly a 96, door sticker said production date was 11/95. it was the original motor in it for sure.
Originally posted by sharkeyhmm, thats weird. i thought they ended production in 95. but even then, i have a friend who has a 96 corsica with a gen 2 3.1l. i checked the vin number out, and it was deffinitly a 96, door sticker said production date was 11/95. it was the original motor in it for sure.
I know for a fact that 95 models have a different 3.1(3100). I looked at one today because the motor was for sale. From the info that I gathered so far, the 95 engine will work with some changes. Your friend may have had a 96 with a 3.1 but it should be different from the 3.1 I need(90-94).
it would look to hacked together if they went from a gen 3- gen 2 if they were looking to save money on it. im wondering if its a factory freak. everything in the engine back looks factory.
anyways, it could be the water pump, or he could have had a clogged rad. make sure you check to see what the oil looks like, look for leaks, pull a couple spark plugs at random and see what they look like. if its still in the car with a battery hooked to it, do a compression test.
Originally posted by KingArthurThe motor I found didn't seem right to me, so I didn't buy it. What would it take to get a 3100 from maybe a 2000 Malibu into my 92 Lumina. What needs to be changed?
You can get one from a yard for as low as $350 http://www.car-part.com
1995 Monte Carlo LS
3400 SFI 60v6
Originally posted by sharkeyit would look to hacked together if they went from a gen 3- gen 2 if they were looking to save money on it. im wondering if its a factory freak. everything in the engine back looks factory.
It might not necessarily look "hacked together." They did put the Gen II's in those cars in earlier years so getting all the right parts for it would be simple.
Shawn90 Grand Prix STE 3.1 Intercooled Turbo-3100 Hybrid
99 Grand Prix GT
