Wondering if anyone can give some guidance on running a SFI engine (LX9 - 3.5l from 2006 Malibu) in batch-fire mode. I've got this engine in an MGB, running & driving on MegaSquirt II/extra, but can't pass emissions - I have a minor mis-fire at idle causing high HC in the State emissions test. I think I've tried everything - AFRs from 12ish to 15, ignition advance from 6-25BTDC, various idle speeds; and nothing seems to have any affect on the misfire. It's a 40k mile engine with new plugs, coil, & wires.
I'd heard that batch fire would result in lower idle quality, but didn't think it would impact emissions much (I'm testing at about 1500ppm HC, vs 500ppm max). The engine runs well at speed, and passes the Loaded test with flying colors (~300ppm HC). But at idle, I can hear an occasional miss, and the idle is clearly wandering around.
So, am I chasing my tail? Maybe there's something about the manifold / cam that requires SFI to idle well? (Hoping not to have to upgrade to MS3 with SFI!)
Thanks for your thoughts!
