Hi, some of you guys have probably seen the other thread I am posting in. To make a long story shorter, I have built a turbo 2.8 engine, and there was some failure of the main bearings and/ or crank. I don't have the engine out yet so can't say exactly what happened. It was running awesome, but just started knocking and losing oil pressure so I babied it home and will pull the engine soon.
I've read that the 3.4 DOHC engines have a better crank than the standard 3.1 engine. I can get this crank from Advance Auto (Part Number 10570). Is there a way to know if this was really a DOHC crank and not a standard LH0 crank? They list some casting numbers in the description: Casting 981; 924; X153
I plan to make it a 3.1 during the rebuild but want to get the strongest crank I can. Also going to get rid of the super-heavy stock pistons and go with something better since they have to change anyway for the stroke difference.
Thanks in advance for any insight. I built a boosted 3.1 with a standard LH0 crank and it has held up well. But if the 3.4 crank is stronger, I want to get this one.
Sincerely,
David
Sincerely,
David
