Hello everyone,
My first post. Been a member for a while to gather info on the 660 v6 which I admire.
I was inspired by Fords Ecoboost F-150's performance and how well it drives using a small displacement engines under boost.
Now my question is as the title states, swapping a 660 V6 into a 94's suburban 4x4.
I had a couple engines in the Suburban from 305 to 454 and 6.5 diesel. You can guess which engine was the most fum to drive
. It currently has a carbed 350 vortec.
Well, I like my suburban because it's the best cruiser to drive. Hauls the family with plenty of room to spare. But with $4.00 dollar gas it's hurts to fill it up.
So I'm thinking of using a RWD 660V6 out of a third gen camaro/firebird. A 2.8 or 3.4 under boost. The 660's strike me has bullet proof engines that can handle some abuse and heavy loads.
I'm leaning to the 2.8 because low end torque they offer even under boost. I like the 3.4 but it has a higher rpm torque that wont kick in til later to move the heavy burb'. I can swap the 2.9's upper end on a 3.4 but the compression would be too high for boost, right?
The current tranny is a 700R4 so a simple adapter would bolt to a 660 engine.
The Suburban weights 5,300 lbs. With the V6 swap it would drop down to 5,100 lbs est. Because of the smaller engine and radiator. The Buick Enclave weighs 4,900 lbs and is equipped with the 3.6 v6. So I don't think I would be far off.
Do you think the 660 would offer gas mileage increase to the Suburban?
Chase
Chase
