Well Im finally getting rid of my CAI and replacing it with a short WAI to the battery trey. Getting rid of 4 90* bends in the process! I am VERY tired of the rear breather tube, it always falls out. Its going away. Im 100% set on it.
My question, what have you guys done?
Im thinking about a few ideas:
- Tapping the factory hole, putting some type of "plug" with a hose fitting on it and hope I can squeeze a filter on that under the coils/ICM. Maybe a right angle fitting? but then you have a higher chance of oil dripping on the headers..
- Make some sort of metal tube (maybe various pipe fittings) to move the location where the filter would be, away from the coils
- Tapping the factory hole, use an AN fitting with braided hose, same with the new intake pipe. or even using cheap hose fittings, but AN fittings are cooler
but at the same time I would like to avoid extra hoses if I can. Makes things simpler to work on.
any thoughts or opinions?
what do you guys think?
