This is the diagram for the 3.1 vacuum system. I replaced the aging and cracked lines between the air control valves, air vacuum solenoid valve, and the manifold.
Since the diagram is as if you were looking down on the engine from above, it presents me with a problem.
The lines were in bad shape, and may have not been connected properly. My question is where the lines connect to the solenoid. Is the "front" line (that connects to the air control valves) the top line on the solenoid, and the "back" line (that connects to the check valve and the mainfold) the bottom line on the solenoid (the connections on the solenoid are vertical). Or does it not matter which hose is connected to which?
Thanks in advance for helping a very amateur "mechanic" do some basic work to keep the car running.
