Heys guys im trying to swap my beretta from auto to 5spd didnt have much luck finding a 5spd so i was wondering if 5spd trans out of a newer cavalier or sunfire 2.2. Or 2.4 would fit? Any info would be greatly app
5spd trans swap ?
A 2.2 Isuzu 5spd will bolt up, but the strength is suspect. Find a Getrag 282 from a Beretta/Cavalier/Grand Prix in the late 80s, early 90s.
91 SS . 3400/5spd - S&S, TCE, EP, FFP, SPEC, DSS, K&N . GEARHEAD dezign
the fiero world is staring to take notice of the F23 trans that was in the non ecotec 00-02 Cavaliers, I'm in the process of putting one in my fiero. they're supposed to be very strong, and use the same axles as a stock fiero 5 speed, not sure how much work would be involved for a beretta though....
that one is being installed behind a smallblock chevy..."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
Originally posted by tad89 View PostHeys guys im trying to swap my beretta from auto to 5spd didnt have much luck finding a 5spd so i was wondering if 5spd trans out of a newer cavalier or sunfire 2.2. Or 2.4 would fit? Any info would be greatly app
Getrag-284 if time/money is no concern for a little more strength
Only W-Body 282's have different bellhousing bolt patterns for the trans mounts.
IDK about the F23, I do know the getrag swap has been done many times so you have a world of advise and help available. And the getrags have been punsihed often and has proven to hold up well.
If you use a hydraulic throwout bearing, prime it before assembly. I learned the hard way.....you might be fine but the alternative is removing the trans to get to the slave.
You need to bypass the P/N switch to start the car. If you can, get the floor mounted switch behind the clutch pedal. This will be the new safety as the car won't start unless clutch is depressed.
If you put in a newer trans mount, do the same for the engine mount on the other side. I heard it is bad to mismatch (solid vs poly, etc)(old vs new)1996 Grand Prix | 3100v6 L82 | T04E-50 Turbo | Getrag 282 w/ EP LSD | SPEC-3 Clutch
Originally posted by TGP37 View PostIDK about the F23, I do know the getrag swap has been done many times so you have a world of advise and help available. And the getrags have been punsihed often and has proven to hold up well.
The F23 is a getrag, there's more than one behind 3800's, both n/a, turbo, and supercharged, and at least one behind a SBC in fieros. they're a three shaft trans with a syncro'd reverse.
IIRC, a guy on pennock's went low 12's on one behind a turbo 3800, the main thing holding him back was axles..."I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
Originally posted by ericjon262 View PostThe F23 is a getrag, there's more than one behind 3800's, both n/a, turbo, and supercharged, and at least one behind a SBC in fieros. they're a three shaft trans with a syncro'd reverse.
IIRC, a guy on pennock's went low 12's on one behind a turbo 3800, the main thing holding him back was axles...1996 Grand Prix | 3100v6 L82 | T04E-50 Turbo | Getrag 282 w/ EP LSD | SPEC-3 Clutch
Originally posted by tad89 View PostWhat years did the f23 come in an that was only with the 2.2 l right 2.4 is different i think"I am not what you so glibly call to be a civilized man. I have broken with society for reasons which I alone am able to appreciate. I am therefore not subject to it's stupid laws, and I ask you to never allude to them in my presence again."
