I have a 91 Grand Prix with a dead a/c system.
The car has an 05 3500 LX9, and I modded a beretta a/c bracket to bolt to it so that I could use my r12 compressor. All for nothing since the system has lost its charge. It worked before the swap but is dead now. I jumped it at the relay to force the compressor on and it did not provide any cooled air - so that verifies that the system is discharged rather than having an electrical fault.
I believe any late model 3x00 compressor will bolt right to the LX9 block and I can ditch the beretta bracket all together. Getting a 3x00 compressor is the easy part.
Question is, will the 2 existing hardlines that are bolted up to my r12 compressor transfer right over to the r134a 3x00 compressor? Can it be THAT easy? Then a simple evacuation and charge and I'd be good to go, cold air and all (and right now most importantly good defrosting!). What about the a/c clutch, by some miracle is the electrical connection the same between the new and old compressor?
I know most people change the accumulator and dryer as well. Honestly what is the difference between those parts? I don't know much about a/c. I believe one of them is the large cylindrical piece, what is the other part? What happens if I don't bother changing them?
edit: I see that a new accumulator (Autozone) for the 91 system is only $20ish, so no reason not to change it. When I tryed to look up "dryer" it came to the same part. Are they one in the same? And just what does that part do? It seems just like an expansion area?
