im going to be mounting a 3.4 out of a 94 camaro in a 1993 s10 ... has n e one been able to use a front wheel drive block in a rear wheel application....the problem i see is the starter is on the wrong side and it doesn't look like i can mount it on the opposite side of the fwd block .....my concern is i bought a 3400 from a friend that has diamond pistons that are .060 over and i don't want to have to machine my 3.4 block for .060 if i can avoid it
any wisdom would be great..
thank you
thank you
