I am at the tuning stage of the install but am new to it. The car was starting but it was running very poorly. Now today the car will not start.
There is 45 psi fuel pressure while cranking. I sprayed some starter fluid in the tb and nothing. I pulled the front spark plugs and they were wet with fuel but otherwise ok. I pulled a plug wire and held it near a ground and watched as the car was turning over. It would spark once then nothing. Try turning over, spark once and then nothing. I swapped coil packs but there was no change.
What is the next logical step?
Thanks much,
Blake
Thanks much,
Blake
