Does anyone know when the 3.9L vvt engine switched to the new bolt pattern? Which cars and years were which bolt patterns used in?
3.9 bell housings
Originally posted by NateD4 View PostWhat would be on a 2007 G6 MU9?
I am looking at hooking it to a 2010 3.9 from an impala (LZG engine).
Thanks
NateOriginally posted by robertisaar View Postthe F40 has multiple patterns(depending on the engine it is hooked up to), the 3.9 does not.-60v6's 2nd Jon M.
Originally posted by NateD4 View PostNot quite that easy. The trans I'm looking at is already out of the car.
I also want to use a 3.9 with active fuel management.
The only car that has it is the impala and I'm not sure what bell housing it has since it hooked to an auto.
Now what you're going to do about a DOD (AFM) engine bolted to an F40 I don't know, as DOD was not used with the F40 and unless provisions have been found to tune out the BCM/TCM input the PCM will be looking for from the auto trans the PCM will set codes that will affect driveability.
