Working on my 2005 Equinox 3400 (LNJ) build into a 86 Fiero with a 4 speed manual, anyway got to the AC compressor and got stuck. The motor I got didn't come with a compressor so, because of the PCM and wiring harness I'm using (98 Monte Carlo 3100) I decided to pick up an AC compressor from that motor. Well it seems the bolt holes don't line up at all between the compressor and the bracket, nor the holes on the block.
So my question to you gurus out there, can a 98 PCM and wiring harness run a 2005 Equinox AC compressor? Will I need to splice the connectors but it'll work? Or does the Equinox use some weird PCM control on the compressor that won't let it work properly on an old style computer? Would it be easier to fab up a new adapter for the old style compressor?
Here is a picture of the AC bracket I have on the motor.
