I have a 1995 Lumina LS 3.1. My oil pump went out in november. I have replaced the oil pump, pick up screen, kept the OEM shaft. Also have replaced the sending unit. In the process I replaced a bad coil also. I have the car put back together and still have an oil light. I have no idea where to go from here. prior to the pump going out, I had no problems other than that coil. I did replace with an OEM one. Also put NGK plugs, and BWD wires. While the cradle was dropped, I replaced the transmission mount and motor mount too. All this is irrelevant to oil pressure, just making sure everyone knows all that has been done. The car has 92,000 miles on it. Only thing is it was wrecked and did sit for almost 2 years but was periodically ran.
