Lightweight battery info
  • Lightweight battery info
    Ok so ive been thinking of getting a light weight battery for my z,
    i found this one, only weighs 11lbs, its a motorcycle battery that has 280cc hours
    Keep in mind i wont be driving my car in winters anymore so the battery would never have to perform under 55degrees
    Has anyone ever used a lightweight battery such as this in a daily driver?
    Yea you can use it but why?
    Just make sure you clamp it down properly. If you have high end stereo I would not use it though.
      just take a good piss and shit before you go racin'
        Unless your car weighs in under 1000 kilos, I dont see justification in buying such a battery...
        Instead, use battery weight to your advantage; you can relocate it and use it as ballast weight to even out the weight balance
        Originally posted by Mars
        Haha ^ Wrong Wheel Drive.
        No 60šV6 at the moment
          spend your money elsewhere...
          if you want to lighten your car up before a race, take your passenger seats out. If you have a girl, she can sit on the floor.
