rocker studs stripping?
  • rocker studs stripping?
    any1 else have problems with 3400 rocker studs pulling out? a third one came to my job today with this problem. the first two were rendevous and the third is a equinox. all 03+. i didnt know this was a common problem should i be worried with my 3500?
    I believe it. They changed to 8mm bottoms on the stud from the original 10MM. Seems like a dumb ass move to me.
      ive seen it as well. time-certing the holes seems to be the best option. ive always used time-certs for stripped aluminum and have had better luck than those heli-coiled.
      [SIGPIC]
      12.268@117... 11's to come!
        How does a time-cert look can you post a picture?
          threaded inserts threaded, stripped threads, threaded inserts, blown out sparkplugs, stripped threads, stripped out theads, inserts threaded inserts, ford sparkplug repair, threaded insert thread repair spark plug ford blown, blew out ford sparkplug, stripped theads, threads stripped out, threaded inserts for stripped threads, repairing stripped threads, thread repair kits and inserts, repairing sparkplugs threads, sparkplugs threads have stripped out, screw thread inserts, striped out threads, threaded inserts, automobile threads blown out, motorcycle threads stripped out threads, not helicoil use time-sert thread repair, screw thread insert, inserts for screw threads, screw thead inserts have stripped out
