hehe, well we got one today. i did some in depth looking at it...
things i noticed
the lower intake manifold gasket now has a Rubber lower valley gasket with RTV sealant now just in the corners. looks like GM is finally trying to help solve intake gasket issues a bit more. IF this is going to fix things?? who's to say.. dont know. but there IS now a gasket along the block end rails where the bottom of the intake meets the block.
i noticed the intake gasket thing due to, yeah as everyone knows, NO power steering pump sitting there. looks kinda cool like that.
there IS NOT a Crossover pipe between manifolds anymore!!
Both front and rear exhuast manifolds are separate from each other.
each manifold has its own O2 sensor. and the front exh manifold exits into a Cat converter. then goes now under the pan on the pass side around and meets up in a Y pipe at the rear exh manifold pipe to exit as one single pipe.
Drive by wire throttle actuation. (not a big fan of this stuff..)
hmm.
the IGN coil packs have changed. different looking.
um... what else.. shit i was looking at it quite a bit and mentally taking notes to tell all... what else...
well I dont like the look of the new plenum thats for sure. meh.. i like the 3400 style look with the separated runners and such. more flowing, has more visual apeal than this new box thing.
i'll take a look at it again today and take my Digi cam to work to take pics of things for you boys.
later.
things i noticed
hmm.
later.
