i was sent here from a camaro forum. i have a 1995 camaro V6 3.4 liter. Vats is junk. Vats is junk. Vats is junk. I bought the car a few days ago. I got a great deal on it. It was broke down. Its the vats. I bypassed the starter relay, and all hail the car will start for about 2 seconds and die. I know its the fuel injectors are shut off. I built a bcm bypass module (sends 50hz to the computer, to trick it into believing it is function correctly and the key checks out) problem is i dont know where my fuel enable wire is, and im not even sure where to look, at first i thought it was a wire on the silver metal box under my glove compartment near the starter relay with a yellow harness and connector which has 2 rows of 12 pins.. although someone from the other forum says thats a part of the air bag system.... perhaps someone could help me find a diagram or point me in the direction to find this wire i need to tie my signal wire into from my bypass module. The bypass module has 3 wires, ignition 12 volt, ground, and signal wire out, i really just need to find the signal wire, although if you tell me which harness i need to tie into, id be happy knowing which wires in that particular harness were the ignition 12 volt and ground as well as the fuel enable signal wire. Please help me... ive had the car like 3 days and am already getting frustrated and cant wait to actually test drive it. Also i know you can have the ecm or pcm reprogrammed to not even cut the fuel off, am i correct when i assume the ecm or pcm or whichever it is, is the computer under the hood on the firewall on the passenger side of the car? where would be the best place to bring it to get it reprogrammed if all else fails? please let me know something thanks so much. K.C.
PS i have been searching for 2 days so please dont tell me to search, thats been tried and failed! ive read and read and read. Thanks. K.C.
