Drill/Tap oil pan turbo drain
  • Drill/Tap oil pan turbo drain
    Hi, despite searching, I can't find any info. Curious to know what others have done on the 3100/3400/3500 cast alum. oil pans...
    Does 1/2" NPT tap and 23/32" drill bit seem like the right thing here? With a male 1/2" NPT to -10AN male fitting ??
    I wonder if i should go with NPT thread or just regular machine thread with a oring seal. ??
    this : http://www.summitracing.com/parts/RUS-670710/
    OR
    this :
    http://www.summitracing.com/parts/RUS-660501/
    I am not afraid of drilling and tapping, Ihave the pan out already... I just want to know what would be the best way to do it, NPT or machine thread. What's stonger ??
    I went with NPT thread, 1/2 NPT to -10AN.
    Oh and, good choice on the turbo.
      Here's a link to a thread that is similar to what you ask... Mostly after post #15
      Good luck!!
      Tom....
        I suggest you drill it a little small and use a tapered reamer to finalize the taper, or you may not get a good seal. Don't forget, you should have only about 2 turns until it's hand tight.
        For ease (and accuracy if you are using hand tools), the machine thread and o-ring may be better.
        The first link you posted is made more for a punched steel pan, drill a hole and put the nut on the other side.
          If you have the pan out you could weld in a bung and never worry about leaks. The pans are cast and if you clean up the area where you are going to weld it welds real nice.
