I believe all you are going to get is the engine size (unless it falls in the years the 3100 and 3400 used the same heads) and year range. They don't change part numbers for each year and vehicle model.
91 Black Lumina Z34-5 speed 92 Black Lumina Z34 5 speed (getting there, slowly... follow the progress here)
Its for large port 3100 and 3400 engines. Not the latest casting but still good. 10mm rockers only. 487 castings are newer and can be 10 or 8mm rockers.
What does the 8 or 10mm mean? Never heard this mentioned here at 60deg. before
In ~2004, GM went to 8mm studs for the rocker arms. Prior to that, they were 10mm studs. 8mm, IIRC, is what the LSx engines use, so it was a shift to limit the number of different parts and whatnot between various engine families.
