My 3.1 heads where checked today and found to have no cracks and where .015 and .017 warped perspectivly (left and right). My machinist says that head spacers can be used after he resurfaces the heads. This would eliminate the need for longer pushrods to make up the head milled difference. Question is how many of you have used a head spacer and is it a risky solution to warped heads?.....Thanks.....Tom
3.1 head spacer
Originally posted by SappySE107 View PostLonger pushrods for milling heads? Maybe shorter, but not likely. They do not make head spacers but they do make rocker arm shims to lift them up .010 or .020".
Not worth the trouble..
Which 3.1 is this?
Thats a lot of milling for stock aluminum heads. Some shops have machines to twist aluminum heads back into shape or at least get them within .005" and then you can mill them. I would just get some used heads that are not warped and rebuild them.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
so you are looking at a max of .017" milled then?
People have been running .020 thinner gaskets on gen2 3.1's forever without issues. I doubt you'll have any. Your compression will be higher of course so you may gain a little power.
3.1 head shim
Check this out. The owner of this machine shop (40 years experience) also told me my head had been worked on before because i have bronze valve guides. Says he's never seen bronze used before in the 90's 3.1/3.4 GM. Problem is i told him this car was bought new by me in 1997 and had 3 miles when purchased and never out of my sight. So he say's, "Well then it's a test car!!! HuH!
Originally posted by asylummotorsports View PostGM would at times install bronze guides to "save" a head rather than scrap it.
It's also why there were .005 overbored engines with pistons you can't buy.
Chrysler was famous for that on 340's and Hemi's.
Usually late in a production run to get stuff out the door.
Originally posted by SappySE107 View Postguides or guide liners?
P/S going to the scrape yard to look at 2 3.4 engines out of the car. Does not know what they came out of. Where are the numbers to check for engine size accuracy and year of engines.
