Help inspecting short block, please
  • Help inspecting short block, please
    I am considering buying a short block built for boost. A 3400 LA1. Roughly 120k miles. Includes head studs, no cylinder heads.
    The car had a history of overheating. They tried to fix it but couldn't. I suspect one of two conclusions.
    1 - typical problem that wasn't fixed such as bad head gasket, water pump, clogged rad ect.
    2 - the block is cracked or there is a cracked piston.
    But for $300 it is a steal?
    How can I inspect for cracks that I can not see with the naked eye?
    Unless I can prove the block is good, I won't buy it.
    But if the short block IS good, it would be a GREAT addition to my turbo project. I would love to be hitting 15-20 psi boost.
    Only problem is getting a new tranny at those boost levels. But if I am going to swap the short block, I would do it then as well. Otherwise, I am just sticking to my stock block, tranny and 5-8 psi boost.
    Any advice on how to inspect the block? It seems like to good to be true for such a price?
    btw, it is a friend of a friend transaction, so the trust factor is iffy.
    $300 seems over priced for a block you suspect there is an issue with
    As of April 2
    Engine: 2006 SV6 3500 LX9
    Trans: 2002 Getrag F23 5speed
    Injectors: #36 GTPs
    TB: 65mm TCE
    Maf: 1999 3400 Montana.
    Beverages: Ice Cold CANADIAN.
      Only way to really do it GOOD would be to get it sonic checked, but then it has to be down to a bare block. I would look at what parts are included in the short block, look at the prices of the parts if you bought the separate, and then the cost of a different block. It still might be worth it even if the block is bad.
        Even if it included hardened internals that can handle boost? Such as stronger pistons, rods and crank?
        I believe it has a double timing chain or whatever its called. The timing chain is doubled up.
        Ehh, I'm going to probably pass. Especially since I want to rebuild a short block myself in the coming year or two. And take my time at it. Get a known good block bored/honed, stronger pistons to match. Basically build the short block to handle heavy amounts of boost. I would like to get 30-35 psi. But I need to investigate parts and what not. The goal is to have a well built car with lots of boost, NOS and not have any issues. It will be my mechanical pet.
          It is worth considering. I have some investigating to do.
          Thanks guyz
            A 3X00 short block here is only $99 so I would say you are getting ripped
