I am considering buying a short block built for boost. A 3400 LA1. Roughly 120k miles. Includes head studs, no cylinder heads.
The car had a history of overheating. They tried to fix it but couldn't. I suspect one of two conclusions.
1 - typical problem that wasn't fixed such as bad head gasket, water pump, clogged rad ect.
2 - the block is cracked or there is a cracked piston.
But for $300 it is a steal?
How can I inspect for cracks that I can not see with the naked eye?
Unless I can prove the block is good, I won't buy it.
But if the short block IS good, it would be a GREAT addition to my turbo project. I would love to be hitting 15-20 psi boost.
Only problem is getting a new tranny at those boost levels. But if I am going to swap the short block, I would do it then as well. Otherwise, I am just sticking to my stock block, tranny and 5-8 psi boost.
Any advice on how to inspect the block? It seems like to good to be true for such a price?
btw, it is a friend of a friend transaction, so the trust factor is iffy.
