Is a UDP safe for a 3100 engine??
i don't see why it wouldn't be... wrong section to post this in though...(EDIT: fixed by the Ben-God)Last edited by robertisaar; 12-03-2009, 06:09 PM.
Who can even see the crank pulley anyway though? Covered up by plastic and at the bottom of the engine bay...
Some run them on stock engines without failures, might shorten the life of the chain, and/or crank. Modified engines we are staying away from them since a modified engine needs dampening and to last due to the added stresses of power/high compression/cam/etcsigpicNew 2010 project (click image)
Originally posted by 1988GTU View PostYou'd be surprised how well you can see them.
not the best pic but its all i have. just picture a plastic shield from the strut forward.
same area with the tire on. just how much of the pulley do you actually see. car was still a little jacked up at that time but now it sits 2" lower.
actually i like the splash shield there, keeps the crap off the belt. i finally got around to putting it back in a few months back.Last edited by geldartb; 12-07-2009, 04:19 PM.sigpic
99 Grand Am GT
1357 cam 227 233 .050 dur 515 515 lift 112 lsa
Mine has a splash guard as well, can't see the crank pulley unless you are over the engine bay with a flash light...sigpicNew 2010 project (click image)
this is just like the billet aluminum front transmission mount i have. you cant see the damn thing unless your really looking and move the engine harness
meh my ac compressor is sitting on the garage floor. bottom bolt doesnt line up and it was vibrating against the oil pan. sounded like i had a low end knock.Last edited by geldartb; 12-07-2009, 07:13 PM.sigpic
99 Grand Am GT
I took mine off and noticed 0 change in power, even ran the same track times.
wait till the ones with a dampener come out... then it might be worth it.
