Originally posted by SappySE107
		at least a few things the 3800 has going for it,
oil pump is in the timing cover, so im guessing it can be replaced without pulling the engine, and there is no oil pump driveshaft.
the bottom end has more side area so that the caps sit up in the block, rather than being exposed.
I dont buy that the area's around the cylinders are stronger than on a 60º, we have the entire lifter valley area tying the 2 banks together.. the 3800 is very open.. almost like running twin inline 3's.
I guess overall I just prefer the compactness of the 60º more than anything. You can virtually fit it in any application that used an I-4, and probably double your torque output instantly.
All you 3800 guys, id really like it if you'd bring some advantage data to the table here instead of "3800 rox U Sux0rz!". In all of these threads we have made, not once has someone come to the plate with measurement specs.
