does anyone on here happen to know the stock camshaft profiles for all or most of the different 60* engines and also are any of them interchangeable with eachother (granted that you get custom pushrods)?
Stock Camshaft Profiles & Compatibility List
I only see lift as a spec listed as .2727" I was wondering what the stock cam specs are too for gen3.sigpicNew 2010 project (click image)
.2727 x 1.6 = .4363 lift...
All the cams are the same. They have 196 duration.
Napa specs
* Cam Lift (Exhaust):.272"
* Cam Lift (Intake):.272"
* Cam Timing at .050" Lobe Lift (Exhaust Close):12 Deg BTC
* Cam Timing at .050" Lobe Lift (Exhaust Open):32 Deg ABC
* Cam Timing at .050" Lobe Lift (Intake Close):29 Deg BBC
* Cam Timing at .050" Lobe Lift (Intake Open):15 Deg ATC
* Degrees Overlap:39 Deg
* Duration at .050" Lobe Lift (Exhaust):197 Deg
* Duration at .050" Lobe Lift (Intake):197 Deg
* Lobe Centerline (Exhaust):111 Deg
* Lobe Centerline (Intake):113 Deg
* Valve Lash (Exhaust):Hyd.
* Valve Lash (Intake):Hyd.
* Valve Lift (Exhaust):.436"
* Valve Lift (Intake):.436"
also
no, the old flat tappet cams are smaller.
this is the 'HO" cam from the gen2 engines.
Cam Specs:
Part number: 10118636
Material; Cast Iron
Drive; Crank via chain drive
Weight: 3.098 kg/6.83 lbs
Valve timing at .050”
Intake/Exhaust duration: 194/202 degrees
Intake valve open: 13 degrees after TDC
Intake valve closed: 27 degrees after BDC
Exhaust valve open: 29 degrees before BDC
Exhaust valve closed: 7 degrees before TDC
Intake lobe center: 109 degrees
Exhaust lobe center: 109 degrees
Intake Lift: .2626”
Exhaust lift: .273”
Lobe separation angle: 112
Rocker ratio: 1.5:1
Total effective lift with 1.5:1 rocker: .4095”
