2.8L exhaust leak, causing sluggish accleration?
  • #61
    yeah that is one good thing about GM: slow to adapt to new things...
    MOST things should plug in directly, the only two things i can think of ATM that won't are EGR and the coolant temp...
    • #62
      Yah he mentioned those too. All I have to do is take them out of the 2.8 and Stick them on the 3x00. Real easy.
      How many bolts hold the tranny on to the engine? I hope the 2.8's tranny fits the 3x00.
      1988 Grand Prix - project
      1999 Ford Explorer 4x4 - daily driver
      • #63
        for coolant temp: the newer motor uses a single temp sensor that has three wires instead of the older setup that uses 2 sensors: 1 with 1 wire and another with 2 wires...
        EGR: does it use the same connector? BTW: which EGR did your GP come with? if you have the hood open yet, take a pic of it and we'll know if its a backpressure/EVRV or digital...
        the tranny will DEFINITELY bolt up. is it a 3 or 4 speed?
        EDIT: might need to swap the guts of the 2.8 TB onto the new one so that the linkages match...
        • #64
          Thanks Robert,
          I think it is a four speed (1,2,3,D,R,P).
          I hope it doesn't need to have the TB taken apart. I know a lot about diesel fuel systems (I have a degree in Diesel Technology), but I don't know much about TBs. I took Auto. Tech. in High School, but mostly all we dealed with was carbs.
          • #65
            Oh by the way,
            Will the 2.8s ECM plug into the '00 3x00? The guy I got it from said it should.
            It didn't come with the computer.
            • #66
              ...by ECM if you mean all of the connections, then yes except for coolant and EGR... but those have been worked around...
              what ECM is it? namely does it have a MAF or MAP sensor
              yes, you have a 4 speed (4t60, th440-t4 whatever you want to call it).
              swapping TB guts isn't that hard, i'm trying to think of who did it recently or made a guide of it...
              EDIT: and your ECM WILL require tuning... a 3x00 wants a lot different fuel and timing compared to a 2.8...
              • #67
                Ok,
                How do you tune the ECM? Is it very hard?
                The 3x00 has a MAF and I think the 2.8 does too.
                • #68
                  as per my own rules:
                  ask Ben about tuning.
                  he should be able to hook you up with a good tune...
                  • #69
                    Who's Ben?
                    • #70
                      this guy:
                      he happens to own WOT-Tech, which is that nice banner you see near the top of the page.
                      • #71
                        Thanks! I'll go to that forum right now.
                        • #72
                          not quite a forum...
                          • #73
                            There is a forum about WOT-Tech though,
                            I got on the WOT-Tech website: I couldn't find a 2.8 to 3100 swap chip. (is that what I need?) All they have is 2.8 to 3.1 swap chips '88-94.
                            What would happen if I didn't tune the ECM right away? Would it still run?
                            • #74
                              talk to him personally. then he'll set you on the right path.
                              if you didn't have it tuned right away: it would probably run, but i would be concered with knock/severe lean issues...
                              • #75
                                Ok, Thanks!
                                Does he have an email? My phone doesn't work quite right.
