oil pressure prime tool
  • oil pressure prime tool
    I know this has been talked about in previous threads, but I think this is the best and least expensive answer to the 60* engine oil prime question.
    Many years ago the prime question came up with lifter/cam replacement and not wanting to start the engine "dry". The answer was a later model S-10 2.8 distributor.
    Remove the upper plate, rotor mounting flanges, any centrifical weights/plates, etc. Once everything is removed, the shaft will fit in a 1/2" drill chuck. Next is the hard part - the lower gear. I had the gear from the distributor "de-toothed" on a lathe, but the same could be accomplished with a grinder or belt sander.
    In the attached pics, the relief channel in the distributor housing marked with a "D" casting (below the O-ring) is the lifter galley channel for the 1-3-5 cylinder lifters. Without the housing in place, a huge hole is left open at the back of the galley, and the rear lifter set won't get proper pressure.
    A washer was welded to the upper shaft to aid in installing and removal of the unit during the prime.
    I gutted the housing of my old distributor and cut the top off on a lathe and bored the hole out in the middle. Essentially I just made a plug with a hole to pass an extension and a socket through to turn the pump with a drill. Same effect in the end.
      I just use lots of assembly lube and cross my fingers.
        Amen brother
        94 Firebird 3.4 DD
        252000mi. All original
          -Pull your ignition fuse and fuel pump fuse
          -Crank starter for a few moments, stop, repeat a few times
          -Replace fuses
          Motor is primed!
          SpudFiles
          Theopia
          Enjoy life online.
            -Replace fuses
            Motor is primed!
            And unless you used lots and lots of assembly lube the damage is done.
            I made my priming tool from a stripped down dizzy also.
            87 3.4 4x4 blazer
              And why is that? Still turning the motor at very low RPM's.
              SpudFiles
              Theopia
              Enjoy life online.
                The Whole point of priming the engine is to get the oil to fill up all the galleys and pumping before you ever turn the engine over. I don't care if you turn the engine over by hand you still risk dry metal on metal contact and run the chance of ruining something. With (any kind) the priming tool all you are turning the oil pump and building up pressure. Nothing else in the engine ever turns over before there is oil everywhere that its supposed to be first.
                87 3.4 4x4 blazer
                  Agreed. On a brand new engine there is a lot of empty air space in all the galleys that need to fill up with oil before pressure will begin to build. You can feel it when you begin to prime a new motor.
                    + a distributor plug from Dave I got at the meet= my new priming tool. Just had to take the plug apart and bore out the hole in the center some.
                      $10? thats not bad... how much did dave's dizzy plug cost?
                        Nothing. It was in a spare parts bin he brought in case anyone needed misc. items. The deal from Harbor Freight on its own sucked and with the big open space under the "plug" that came with it wouldn't let it build enough pressure to oil the top end. With the dizzy plug in there (like it should be) it should have no problem But yeah, before last night, I was part of the "use most of the bottle of assembly lube and cross your fingers" club, lol. I haven't had a chance to try this sucker out, and hopefully I won't have to for a while.
                          i used an old oil pump driveshaft, welded a 1/4'' 6'' flexible socket extension, and i used a high speed drill. easy few mins and it was primed!
                          [SIGPIC]
                          12.268@117... 11's to come!
                            Exactly Right...
                            Please visit my photo-bucket site to view my design/parts list and images of a practical and inexpensive (fully sealing) Oil Pump Priming Tool for use on 60* V6 Engines:
                              I got a chance to use my prime tool deal (joy...) With my DeWalt drill with a rated speed of 2500 RPMs I got 67 psi on a bone cold engine with new bearings and it took about 7 seconds from the time I stopped the drill to the time my gauge hit 0 psi.
