Not sure of the best section to put this under but here is the current cost of my 3.4 aluminum head build:
3.4 long block (supposedly with 80K on it and usable as is) and a bonus set of 2002 3400 heads (no rockers) off of Craigslist
-$150
Transport of block and heads from Chicago to St.Louis using rideshare on Chicago's Craigslist
-$60
New Sealed Power cam bearings from Advanced Auto
-$20
New Mahle pistons for a Transport Van .030 over from Northern Auto
-$40
Rings and Shipping for said pistons
-$100
Brass Freeze Plugs
-$20
Machine work (hot tank, bore and hone, cam bearing installation, freeze plug installation, clean and polish crank, press on new pistons)
-$286
Major components I still need- Oil Pump, Main and Rod bearings, Timing set, Cam kit, custom pushrods, and gaskets. That should cover the long block. Then I need to start grabbing my intake/fuel delivery parts. This is a little more expensive than I expected but still waaayyyy less expensive than a crate motor...
-$150
-$60
-$20
-$40
-$100
Brass Freeze Plugs
-$20
-$286
