3500 a/c delete
  • 3500 a/c delete
    does any one know it a a/c delete made for a 3400 will fit a 3500? i cant use the idler pully like superdave because my motor mount bolts there.
    nobody?
      What if you just got a shorter belt?
      SpudFiles
      Theopia
      Enjoy life online.
        ur sayin go from the crank pulley right to the water pump? i think it will hit the motor mount. pcguy did ur 3100 compressor bolt up i was skiming the sticky and didnt see
          shorter belt wont work, ive been looking at my 3500 and wondering if ima use AC or not..
            Yes, my 3100 compressor works... minus 1 bolt (bottom bolt). The mounting hole doesn't align but I am at least the second person to leave it off and be fine.
            SpudFiles
            Theopia
            Enjoy life online.
              so if that a/c delete bolts in the same places as the compressor it should work. any one know if it does?
                ill check at work to see if we have one for a 3400 instock, if we do ill see if itll boltup to my block... (3500) ill post tomorrow on what i findout
                  sorry, we dont stock the gm ac bypass :/
                    it would be no big deal if i could get one at a autoparts store then just return it but i think its special order and they dont take returns on special orders.
                      just start calling around, im sure one of the smaller-non-chain stores might stock it...
                        auzone has one in stock a couple towns over im a try to pick it up today and check.
                          i just ordered one from dorman, its cheaper then a AC compressor, ill let you know what i find when it comes in.
                            i got one from autozone it fits but had to cut the bracket a lil and the pan a lil but it works.
