just thought i would post to let everyone know today i was workin on my isuzu rodeo and pulled off the throttle body to clean it just for hahas i tryed it on my 3500 upper and it lined up perfict just the idle air control would need some kind of a connection but it bolted right up no prob and it is a gm engine.
another 3500 throttle body option
ive been tryin to find a throttle body that will bolt right on just so i can get it running but i also found another throttle body that fits.
a 95 z24 throttle body will bolt up if u elongate the holes a little and it looks like idle air control will work. im checkin the bore but i think its around 56mm[/IMG]
<a href="http://s675.photobucket.com/albums/vv113/gar70614/?action=view¤t=DSC03007.jpg" target="_blank"><img src="http://i675.photobucket.com/albums/vv113/gar70614/DSC03007.jpg" border="0" alt="Photobucket"></a>
I know a Quad 4 TB will bolt right on. (They are 56mm) But the linkage is arse-backwards.
I had one on for a while, then had it bored and sleeved to 62mm, then bought the TCE 65mm unit from Ben. (Best choice!)
The 56mm is a little small for the 3500. 62mm is actually enough for most stock applications.Last edited by asylummotorsports; 04-21-2009, 01:39 PM.
i believe that 3.2 is the honda motor. the rodeo is the samething as a honda passportENGINE HAS INTERNAL DAMAGE. THIS MOTOR WILL BE TAKEN OUT OF THE FIERO AND REPAIRED IN TIME. UNTIL THEN, A L67 WILL RESIDE IN ITS PLACE
87 fiero gt 5spd 3500, 1280 cam and PR, ls6 valve springs, port and polished heads, ported lim, ported uim, 4.3 70mm tb, ported trueleo headers and y pipe, 2.5 inch ex, flowtech muff, 7730 ecm, moates.net APU1, self tuning *learning* (GOT FROM MY BROTHER, divorce reasons.)
Just go to www.car-part.com and search for 2001 intrigue 3.5L throttle body, then grab the adapter from the WOT store here. 65mm GM TB bam done. Or the 65mm billet and adapter if you want it to use the 3100 linkage swaped over.sigpic New 2010 project (click image)
