another 3500 throttle body option
  • another 3500 throttle body option
    just thought i would post to let everyone know today i was workin on my isuzu rodeo and pulled off the throttle body to clean it just for hahas i tryed it on my 3500 upper and it lined up perfict just the idle air control would need some kind of a connection but it bolted right up no prob and it is a gm engine.
    What size is that and what motor is the rodeo?
      its a v6 i belive its a 3.2? i just got it so not positive but i do know its a gm engine ang it fit great exept the idle air control came out to nothing above the manifold.
        it comes out right next to the hole for the breather tube to the front valve cover.
          Year?
            sorry 97
              ive been tryin to find a throttle body that will bolt right on just so i can get it running but i also found another throttle body that fits.
              a 95 z24 throttle body will bolt up if u elongate the holes a little and it looks like idle air control will work. im checkin the bore but i think its around 56mm[/IMG]
              <a href="http://s675.photobucket.com/albums/vv113/gar70614/?action=view&current=DSC03007.jpg" target="_blank"><img src="http://i675.photobucket.com/albums/vv113/gar70614/DSC03007.jpg" border="0" alt="Photobucket"></a>
                sorry pics didnt work let me try again
                    i know it a little small but do u guys think it will work just so i can get my 3500 being run on 3400 electronics goin?
                      do u guys think it will work?
                        I know a Quad 4 TB will bolt right on. (They are 56mm) But the linkage is arse-backwards.
                        I had one on for a while, then had it bored and sleeved to 62mm, then bought the TCE 65mm unit from Ben. (Best choice!)
                        The 56mm is a little small for the 3500. 62mm is actually enough for most stock applications.
                          so it will work to get it running but ill upgrade after i know its all good. do u still have that 62mm sleeved tb? would u sell it?
                            i believe that 3.2 is the honda motor. the rodeo is the samething as a honda passport
                            ENGINE HAS INTERNAL DAMAGE. THIS MOTOR WILL BE TAKEN OUT OF THE FIERO AND REPAIRED IN TIME. UNTIL THEN, A L67 WILL RESIDE IN ITS PLACE
                            87 fiero gt 5spd 3500, 1280 cam and PR, ls6 valve springs, port and polished heads, ported lim, ported uim, 4.3 70mm tb, ported trueleo headers and y pipe, 2.5 inch ex, flowtech muff, 7730 ecm, moates.net APU1, self tuning *learning* (GOT FROM MY BROTHER, divorce reasons.)
                              Just go to www.car-part.com and search for 2001 intrigue 3.5L throttle body, then grab the adapter from the WOT store here. 65mm GM TB bam done. Or the 65mm billet and adapter if you want it to use the 3100 linkage swaped over.
