TGP in junk yard
  • TGP in junk yard
    i found a 1990 black TGP in a local pull and save.. Intercooler and tb clip gone. but it does have the full engine, manifolds, X-over, Turbo and DP, ecu and boost sollinoid all intackt.... I assume they are worth a bit of $$ yet, just didnt know how much... the turbo does have a little bit of shaft play but still looks decent.
    What is something like this worth? if its worth the $$ i will go back and try and snag it all.
    Also is the TGP mono leaf firmer/better then say a Z34 lumina mono leaf?
    S
    Shane "RedZMonte"
    1992 Lumina Z34-VIRGIN (RIP)
    1992 L67 Lumina Z34 (SOLD)
    1990 Turbo Grand Prix (SOLD)
    S
    Not sure. If it is stiffer, it's probably not enough of a difference to be worthwhile. You might want to post this over on the w-body board or TGPForum. I think someone on w-body was looking for a TGP steering rack....and I'm sure other people would want something off of it.
    Matt F.
    TGP 1/4 mile times
    http://photobucket.com/albums/y33/mfewtrail/
    1990 TGP Coupe VIN Database
      you have a pm
      Robert
      New Rebuilt 3100
      New Rebuilt 4T60-E
      Exhaust
      Drilled/Slotted Rotors
      White
      3" Magnaflow Catback
      90 Pontiac Turbo Grand Prix
      5 Speed Swapped
      127,000
      Spec Stage 3 Clutch
      230,000 mile Getrag 282
      Emissions Deleted
      Brand new Engine 1,000 Miles
      Fully Custom Built car
        Is the "Turbo Intercooled" intake manifold worth anything?
        Shane "RedZMonte"
          it would be to someone who was interested in doing a swap and wanted it to look correct, AFAIK though they are identical to the normal 3.1 plenums aside from the different lettering, but you would probably have more luck on the other forums as stated above too.
            Shane - I think this car got crushed, wasnt in Denver or Aurora yesterday.
            2004 Pontiac GTP 3.8 SC
            1997 Pontiac GTP 3.8 SC
            1996 Pontiac GTP 3.4 DOHC
            1990 Pontiac TSTE (x2) 3.1 Turbo
            1990 Pontiac TGP 5Speed
