I'm in the process of returning my wiring harness back to the Turbo Grand Prix specs for running 8F code after failing at my attempt to run the engine with code59 and DIS ignition. I decided I would check cylinder pressure since the engine is very new for a reference as the engine wears. I have allowed the camshaft to start in it's stock position of fully advanced, to be retarded at a set rpm:
1__235 psi
2__220
3__225
4__220
5__213
6__213
I wish I had checked it with the cam fully retarded for comparison. If it runs properly after restoring the harness back to where I had it previously when the engine last ran, the efficiency with that kind of pressure should produce excellent fuel economy.
The last it was driven was just before the upgrades and I noticed an intermittent power drop as if timing was being pulled. I have theorized that it was the old fuel and reduced octane from aging. I powered up the pump to remove the near 2.5 gal and added new fuel. Hopefully it runs without trouble.
I couldn't get anywhere with code59, that's ashame because it's nice code with lots of extras. It just doesn't like DIS systems.
1__235 psi
2__220
3__225
4__220
5__213
6__213
