How do you remove the belt tensioner off a 2.8 MFI?
removal of accessory belt tensioner
on the passenger side there is a tensioner that you need a 3/8 ratchet to loosen to remove the accessory belt off. It is 20 years old and never replaced.
I see it move up and down quite easily with the motor running. In the past it didn't move as much so now i think it needs to be replaced as it does not keep a good tension.
talk about a PITA! find the most shallow socked you can and hope its not too long lol. took me a good half an hour on my beretta with the 3400. you may have to switch to a wrench after a few turnssigpic
You actually have more room to get at it than I do. In the GM service manual for my car you have to raise the front of the car up on stands, remove front passenger wheel, put a jack up to the oil-pan, undo upper engine mount, lower engine with the jack, then access tensioner through passenger-side splash shield.
The same procedure might work for you. It didn't work in my car though, engine wouldn't lower enough. Silly GM.1995 Grand Am SE
