How far to install PS pulley
  • How far to install PS pulley
    Ok im putting a brand new pulley on my p/s pump and dont really know how far to put it on, does anyone have a pic of how far the stock one is on or have a measurement?
    when I do mine, I just tighten it until it stops. It is usually flush with the end you are installing it on.
    Taylor
    1998 Lincoln Mark VIII
      should be flush with the end of the p/s pump shaft...
      00 turbo'd gagt msd 8.5 mm wires,ngk tr-6 plugs,42.5lb inj,65mm tce t.b,ported upper intake,ported lower,ported heads,copper headgaskets,headstuds,160 stat,ls6 valve springs,st3 turbo cam and pushrods,turbo manifolds,custom 'y' pipe,3in open d.p.,dhp powr tuner,garret t3 60-1 .63 turbine,70 compressor,6 pounds of boost...STOCK CAM,STOCK 103XXX BOTTOM END...2.041 60',13.683 @ 100.34
      99 gtp 4in. F.W.I...180 stat..headers...104's...msd8.5's..1.9's...3.4 pulley...cat & res./
