We have roller camshafts, roller rockers and race applications have roller bearings for camshafts.
Why is there no complete roller engine in production yet? roller rod and crank bearings coupled with the above would reduce rotational drag and heat and significantly reduce the load caused by the oil pump by which I nearly sprained my wrist priming with a drill once to give an indication of how much drag it creates. Roller bearings would only require a continuous drop or splash of oil to maintain allowing for much lower oil pressure. There is no doubt a roller bearing would go on non stop for miles probably hours before failure due to lack of oil compared to the current friction bearing setup.
Couple that with the strongest lightest in weight metals for the rotating assembly and engine efficiency should increase substantially resulting in more power from the same engine platform and much better economy.
I would like to conduct an experiment like this one day and maybe even take it to a serious level by attempting to use exhaust gases to open and close valves.
I didn't know roller bearings were being used at all in a crank or rod capacity until a search yielded this:
