the gears on the inside are plastic unless my eyes decieve me, and the TB doesnt get nearly as hot as the exhaust and the heads do, it is cooled due to the rushing air, the low pressure inside the manifold and air rushing past it,
Electric throttle bodies and exhaust cutouts
my dad said that back in the day they just used iron plumbing fittings.. at the track they'd unthread the cap.. lol
Originally posted by Superdave View Postmy dad said that back in the day they just used iron plumbing fittings.. at the track they'd unthread the cap.. lol. The metal caps might be a little hot to take off by hand if you drove the car there
I've seen ones that used 3 wing nuts to hold a cap on them before.-60v6's 2nd Jon M.
Originally posted by gectek View Postthe gears on the inside are plastic unless my eyes decieve me, and the TB doesnt get nearly as hot as the exhaust and the heads do, it is cooled due to the rushing air, the low pressure inside the manifold and air rushing past it,
I was toying with the idea again a little bit today.
Low and behold I held my 3" 2 bolt exhaust flange up to the throttle body and it bolts right up. Now it's even MORE tempting. I think Im going to do it. Just gotta find a place with enough clearance to mount it properly.
If it doesnt last, Im out a whopping $0. If it does, it cost me nothingHonestly I think it will be just fine.
Too bad I have to wait for my custom mounts to be done before I can route the exhaustIt might be a while.
It would be interesting to see what the Aston Martin's and Corvette Z06's use for their cutouts (I know...good luck finding one in a junkyard). I think the Z06's were vacuum actuated like the bypass valve on Eaton SC's. Maybe they're not, but it's another idea to think about.1995 Grand Am SE
Originally posted by Z26-T View PostLOL... wow... Well if it works, why not?. The metal caps might be a little hot to take off by hand if you drove the car there
