in the picture below, you can see my customers LIM has a little corner cracked off. Kinda puzzling as to how this happened, but I noticed it when I was going along doing the gaskets.
The guy doesn't have a lot of money, so getting a new intake isnt his first choice. I'm going to go ahead and MacGyver it with a washer underneath and a bolt/nut deal to secure it. Theres like 50% contact between the LIM and the washer... so my vote is he won't run lean and burn a piston.
on a side note... see the brown ring around the LIM port there? if your were porting the holes... would you use that as an indicator of how far to go for your gaskets? ALSO... how the f%$k are you supposed to port the runners all the way down... what is EXTRUDE honing..
