trans cooler
  • trans cooler
    does anyone know if the a/c condencer would work as a trans fluid cooler?
    It could be used. I am not sure if it is more efficient than a traditional trans cooler or if it will flow enough.
      ok thanks.. i didnt know for syre because friends of mine said the trans fluid would eat away at the lines
        No it would not. The condenser is made of aluminum it would be fine.
          i had a 79 cutlass with a 455 and i used my condenser for a cooler and it worked perfect. it also dropped my engine temp by 20 something degrees
            sweet.. thanks alot...
