does any1 know the part# for just the headgaskets? parts stores cant seem to get them... i figured i would give Gmpartsdirect.com a try
3500 headgaskets
one problem... the 3400 gasket doesnt clear one of the combustion chambers in the head. i think i got a head with a werid cast or something.
no1 seems to have a problem with the 3400 gasket but me lolsigpic
Originally posted by Alxsmt View Postone problem... the 3400 gasket doesnt clear one of the combustion chambers in the head. i think i got a head with a werid cast or something.
hmm i didnt know that, i just got a whole 3500 engine for the topend, it was cheaper that way. it was from an 04 malibusigpic
i just looked them up on gmpartsdirect.com iirc they were a little over $100 for 2
that was for a 2004 malibu 3500.
I used and 04 malibu 3500 for the top end too...
Here are my pics from lining up a 3400 gasket on a 3500 head.
well i went into the dealer today, they want 200 for 2 gaskets...
a little over 100 sounds too expencive too but a lot better than 200!!
and modified, i never thought of using the guide pins! im gonna try that and double check it b4 i spend more money
thanks guyssigpic
Yeah I would try and try again to see if you can't get the 3400 to work.
Can you trim/cut a headgasket? Hmm.sigpicNew 2010 project (click image)
not if its the fire ring over hanging into the chamber... then you end up with a pre blown headgasket before you even start it.
Ok, so the stuff is sealed and that would cause it to split apart then I suppose. Never saw one up close enough to see how they were made. I figured you wouldn't be able to.sigpicNew 2010 project (click image)
