The last time I did a 3400 LIM job, I bought a piece of orange silicone rubber and made my own gaskets like GM uses on the 3500. I coated them in a thin coat of RTV before the install and no leaks after 20K miles....sure beats using all that RTV.
2000 Grand Am GT 2011 Chevy Impala
Bah just use RTV. If you are good it will look clean and never leak. I use black RTV looks fine.
For metal plenum gaskets, if you just want to port out to the larger size cut the felpro gaskets to the center silicone line it should be pretty large or even cut off the slicone line. That's pretty large lol! paper will still seal fine like the older ones..
sigpicNew 2010 project (click image)
1994 3100 BERETTA. 200,000+ miles 16.0 1/4 mile when stock. Now ???
yeah ive been toying around with cutting it to the orange line on the paper gaskets. shaky hands own me.
the lower intake gaskets i bought today came with a small tube of RTV, might pick up another tube to have. i still got the rc car i use it on so it wont go to waste.
cutting it to the orange line is prob the same size as the 3500 gaskets.
sigpic 99 Grand Am GT 3400/3500 -Solid trans mount--TCE 65mm T-body---85mm LS2 maf---1 1/4' TCE intake spacers with 3400 upper--SLP Catback with flowmaster 80--TOG headers
Modded 3400 lifters with LT1 springs---Comp Cams 26986 Springs 1357 cam 227 233 .050 dur 515 515 lift 112 lsa
I bought the sheet of orange silicone rubber at Mcmaster.com I used the Orange 3/32"
I still have some left that I will send you....PM me your address and I will get it out to you.
The center of that line is the same size as the metal plenum gaskets. I have pics of it floating around if so desired.
pics would be cool. i was working on a set last night for a few
If I remember I can take a pic of just the gaskets on top of eachother tomorrow at the shop, but here's one of the paper gasket stuck to the manifold and a rubber gasket on top...
I think you may get a little more area if you cut on the red line of the paper gaskets.
