Hey Im pretty new to this site and sounds like you guys offer a lot of help. I have an '86 camaro w/2.8 and it began stalling at idle last fall. I first cleaned the upper intake and replaced plugs, wires, cap, and rotor and there was no improvement. I then replaced MAF sensor and IAC valve. Still no improvement. I have checked as well as I can for vacum leaks, found none. I replaced the EGR valve and o2 sensor and still no improvement. It idles smooth with a little gas at 1100 rpm but when I let it drop to 750 it will stumble and then surge trying to recover and then stall eventually. It has a little valve chatter but otherwise runs very well. It has 170,000 on the original motor and trans and I'd like to bleed every mile I can out of it. Ive rebuilt a 2.8 in a trooper 5 or 6 years ago and I'm not really in a hurry to do it again. Im all ears.
Chris
Chris
