96 3100 Rods
  • 96 3100 Rods
    is there any engine out there that share the same rods with the 3100?? i just need one rod.. I do have a 3.4 TDC block and was wondering if those rods were the same.. i doubt it but just curious...
    Robert
    New Rebuilt 3100
    New Rebuilt 4T60-E
    Exhaust
    Drilled/Slotted Rotors
    White
    3" Magnaflow Catback
    90 Pontiac Turbo Grand Prix
    5 Speed Swapped
    127,000
    Spec Stage 3 Clutch
    230,000 mile Getrag 282
    Emissions Deleted
    Brand new Engine 1,000 Miles
    Fully Custom Built car
    heres my cam ForcedFirebird, and my bent connecting rod..
    Robert
    New Rebuilt 3100
    New Rebuilt 4T60-E
    Exhaust
    White
    5 Speed Swapped
    127,000
    Spec Stage 3 Clutch
    Emissions Deleted
      OWCH!
      How'd that happen?
      I have 5 extra rods from another engine, but need to press the piston off before I can let it go. ARI sells rods for about $20, though.
      Does anybody know off hand if the timing lobe on the cam is the same on a 3500 as a 3100? I'll print the pic and check out the 3500 cam tomorrow or Thursday if no one knows.
        you know the engine ran fine before i tore it down.. not one funny or odd noise.. it had oil all over from cheap leaky gaskets so i tore it down to change gaskets.. well decided to check the rings and pistons, timing chain and sprokets, and decided to pull the cam for the hell of it.. well just today i found the bent rod and pull the pistons out last friday..
        the cam has grooves in it and the cam bearings are bad.. i have a 3.4 DOHC block and hopefully those rods are good if not u will be hearing from me..lol
        Just let me know about the cam.. im looking around for one and trying to get it on the fast side.. im trying to get this motor together so i can get on the road..
        thanks for the help
        Robert
        New Rebuilt 3100
        New Rebuilt 4T60-E
        Exhaust
        White
        5 Speed Swapped
        127,000
        Spec Stage 3 Clutch
        Emissions Deleted
          The cam is the only thing left in the block, lol. That 3500 got a working over I tell 'ya.
          It has 20 something thousand miles on it. The main and rod bearings looked brand new.
            Here's a pic of the cam and timing lobe. It looks like the 3500's have a 50% lobe and yours is just has a notch. The 3.4 SFI's have justa a tab on them. Wonder why the changes from GM?
              This has been discussed many times. The pickup is different, by the sensor still picks up the leading edge, which is in the axact same location between all 3 designs.
                so i guess they are different... what do i do now??? its knida hard to find a cam... do they make oversize cam bearings?? i havent found any at the local parts store.. maybe someone out there knows if they do ir not..
                Robert
                New Rebuilt 3100
                New Rebuilt 4T60-E
                Exhaust
                White
                5 Speed Swapped
                127,000
                Spec Stage 3 Clutch
                Emissions Deleted
                  So it will work, right Brad?
                    Yes. Worse case would be to replace the sensor with one that matches the trigger...
                      http://60degreev6.com/showthread.php?t=35618&garpg=2
                      So the thrigger from the 3500 can be included. I don't need them. 94GPGTP, is $30 plus shipping fair?
                        yes sounds fair.. the only thing i ask... look in the picture of the 3 cams next to each other... i think its the angle of the camera but the way the cams look it lokks as if going to the right the cams get smaller?? i need a second opnion.. also the cam is in good condiotn.. able to run it?? pm me where i can send paypal payment
                        Robert
                        New Rebuilt 3100
                        New Rebuilt 4T60-E
                        Exhaust
                        White
                        5 Speed Swapped
                        127,000
                        Spec Stage 3 Clutch
                        Emissions Deleted
                          Its the angle of the camera. They are all the same size.
                            ok cool. just making sure..
                            ForcedFirebird PM me.. thanks
                            Robert
                            New Rebuilt 3100
                            New Rebuilt 4T60-E
                            Exhaust
                            White
                            5 Speed Swapped
                            127,000
                            Spec Stage 3 Clutch
                            Emissions Deleted
                              Yes it's in good shape. I bought two 3500's about the same time and I can't remember which had what, but one was 22k miles and the other had 32k. Both were from '04 Malibu's.
                              I'll send a PM.
