Well, I don't have anything here at the motel (in NM) to verify measurements to, but here is a pretty picture for you to look at...
Verify the measurements, and send it to me at Forced_Firebird @ yahoo.com as a .DXF file. I fianally got the upgrade for Mastercam and can convert AutoCAD/SolidWorks files to .MC8
merlot was able to notch the deck lid to clear the alt IIRC. That reminds me I need to bust out my 2 part polyurethane and fill some dog bone torq struts.
Going with the old 3100 style mount or some other lower mount for the Fiero?
Fiero uses lower mounts that I should be able to utilize and I'll need to make some sort of torsion mount bracket from what I can tell. If you just took at z26 3100 and put it in a fiero, the alternator is right where they have a torsion mount placed. I'm not sure if there is enough room to keep the alternator there or not yet. Speaking of that, I've been meaning to look at that 3500 fiero swap to see where his alternator is at. A lot of this project is still up in the air.
Yeah, they worked, but I just haven't had a chance to draw it up yet. I'm heading out on a business trip today, so I'll have some free time at the hotel tonight to go it.
As far as the file extension, it will be DWG unless you want something else. But I've messed with Mastercam before (v9 IIRC) and it was able to convert DWG files.
If you have a big enough scanner, take your spare one and scan it in and save it as a PDF. Then email it to me. I can then recreate it as a CAD drawing and send it on to FF. I can also verify I have the right dimensions by going out and measuring the one in my car.
I believe that the Mastercam 8.1.1 I have can convert it. That would make production much easier
Not sure if not having the crack there or the fact that the top rubber mount I put on is in better shape, but the car has NO slop. Before you'd feel it a little when you hammered it. Now it's smooth, you can lock it in 1st and accelerate and let off and not feel anything. And the car feels really fast, probably because the big rain we had washed all the ice melting chemicals off the road. Last night was the first time I saw the roads dry in a long time!! (ice melting chemicals draws moisture out of air and becomes slimy slick snot).
Brad I'm scanning the mount now. I will try to email it to you.
I was looking at that on mine and wondering how in the world that thing is "good" enough to be the engine support bracket. Either way, I won't be using it, so no worries here.
The new mounts on the timing covers on the newer engines looks like the timing cover has a thin aluminum piece that you put 2 bolts in directly... If that breaks it's a lot more involved to replace!! Like here.
why would GM make a mount out of a metal that can fautigue so easy. atleast steel would have bent. guess they figure the rubber will wear first. but still all it takes is a small scratch for and vibration to get that scratch to propogate into a crack
