PUSHROD crisis!
PUSHROD crisis!
Well lets just say I'm rebuilding my stock 3.1 motor out of my 1997 chevy lumina sedan. I had already bought a new set of pushrods(Stock). But while handling less important matters I happen to mix up the original intake and exhaust pushrods. Well I know the difference between the two, but my problem is not knowing which rod goes where as far as placement back into the engine. Man am I screwed! HELP Please!
Tags: None
intake pushrods are SHORTER, EXHAUST PUSHRODS are LONGER.
INTAKE - 144.18 mm (5.68 inches)
EXHAUST - 152.51 mm (6.0 inches)
Information taken from a GM 1996 W-body platform service manual, page 6A5A-26 3100 SFI V6 engine on-vehicle service L82 (VIN M)Last edited by 3100 MPFI; 01-03-2008, 12:32 AM.Taylor
1998 Lincoln Mark VIII
You could have also just drope them in, its almost 100% obvious when you put an exhaust pushrod on a intake lifter it's just not right.
Originally posted by 3400-95-Modified View PostYou could have also just drope them in, its almost 100% obvious when you put an exhaust pushrod on a intake lifter it's just not right.)
But just match up the intake and exhaust pushrods to the motor. Youll be able to tell.sigpic
3400/Getrag 284 5spd
350/NV3500 5spd
2014 Chevrolet Malibu LS
This is true... sometimes I over estimate someone's knowledge because its like second nature to me...
Well when you start it up you'll know somethings not right. It will run like crap or not run at all or even start and make a terrible noise.sigpicNew 2010 project (click image)
Originally posted by IsaacHayes View PostWell when you start it up you'll know somethings not right. It will run like crap or not run at all or even start and make a terrible noise.
Ok, one reason I'm asking is that when I put a new LIM in my car (it has a noise problem--before and after) I'm paranoid that I may have screwed up the rods, but I think it runs and drives too good to have done that. I'm going to stop worrying about that part.
