big block V6
  • big block V6
    i found this page about a 60 dergee V6 in gmc trucks from the 60's and i was wondering if they shared anything with the 660 of now in days ?
    it would be cool to take this block that is 300-475 C.I and put all the newer stuff on them now that would make power
    No, they don't. There is at least 1 thread on this (prob same site) from a couple years back. Might be more discussion there...
      so no stroker cranks or big bore blocks from that v6 model then that sucks !!
      i tryed to search for that other thread your talking about but i could not find it do you remember the name of it or anything ??
        And probably a time or 2 on the old forum that we lost back in... 03?
          those GMC v6's are about as big as my big block chevy. they sound MEAN in stock trim and the hot rodded ones don't sound 6 bangers at all. every now and then one pops up at a street rod show, I see flat head fords with Ardun OHV heads way more than the GMC v6
          68 El camino 454 speed muncie 3.90 posi 12 bolt,
          80 Monza Spyder nasty buick 231/3.8l v6 200-4R 3.73 posi.
          60 Impala 2 door hardtop L79-327 T56 4.11 posi.
          83 wagoneer torque pig AMC 360 hydradrive (gm turbo 400 with stock sb chrysler bellhousing boltpattern) dana 20 transfer case dana 60 front GM 14 bolt rear. 401 in the wokrs
          91 Z34 now has a hm284. and belly pan in the works
            They made a V12 version. Jay Leno has one in a fire truck.
              ah the twin 6
              '86 Grand National
                I owned a 1965 GMC Custom that had the 305 V6
                I had a 1965 GMC Custom with the 305 V6 that my dad gave me when I was 16.
                The heads were shaped like a 409
                That old engine could drink the gas,but you couldn't bog it down.
                It ended up blowing a head gasket and I replaced it with a 350 because its pretty much impossible to find parts for it.
                When pulled from the truck and sat beside a 454 it was the same size.
                Anyway's the 305 V6 were used mostly in saw mills and in trash trucks in the 60's that pretty much tells you how torque of an engine it was .
