More polished valve covers...
  • #61
    hmm, battery acid and a battery charger. That doesn't sound too complicated
    • #62
      Wow! That's what I want my 3500 UIM to look like also.
      -RUSH
      • #63
        Its not, I've done it before. Heres a link to a how to
        There are better write ups but thats the one I can find easy cause warpig is in my favs.
        87 3.4 4x4 blazer
        • #64
          Also with a lil more reading I can tell you that you don't want to anno these in colors if they are cast. It turns out really bad and splotchy light/dark spots. I've never seen or tried clear so I can't tell you if it'll work or not. All steel, rubber, or anything not aluminum MUST be taken off the part or it will be destroyed and steel/aluminum in an anno bath are not pretty. One lil spring in a paintball marker handle cost me $100.
          87 3.4 4x4 blazer
          • #65
            Yeah the steel splash plates in the back of these will need to be removed. I forget how they are secured.
            • #66
              Exactly. These covers are cast, and even powdercoating may come out inconsistant depending on prep.
              4 torx screws :P
