3.1 injectors
  • 3.1 injectors
    what is the rating in lbs of the stock 3.1L injectors ? i am building a 3.1/3400 hybrid and i am wondering what injectors to use i got my eye on a set accel 21 lbs but i am wondering if they are to big or not ?
    i am using camaro pistons and a crower cam 290/298 .470/.492 and just stock 3400 with ls6 springs it will have headers mns ingnition and also a 125 nitrous wet shot for the track !!
    any comment would be aprecited
    thanks
    Between #16 & #17 @ 43.5 PSI. I have some GM 1996-1995 #21 @ 43.5 PSI that I'd be willing to part with. I also have some 1995 Olds #23 @ 43.5psi 3, but dont know if they can be used in our platform.
      i think that they are the mulitec ones i am not sure i want the ones that can plug right in to the harness
        IIRC the ones I have are all M1's and require the use of stock harness plug ends.
          21-24lb/hr should be perfect with a little tuning...
            late model 3400 injectors or 00+ 2.4L Quad 4 injectors should work quite nicely.
            got zap-straps?
            89 Z24
            13.886 @ 96.16 mph
            street trim - slicks
