Ray glad you got your swap going, we are much further behind you . I pulled off the mechanical fuel pump today, and I have two questions. There is for better words a "lifter" in the block that connected to the pump. Do I need to pull that out of the engine? I am used to a rod on a small block, not this type of assembly. Also, upon taking the bracket that held the fuel filter for the 88 motor,(dropping a 85 motor in) it appears that it will cover the old fuel pump hole, and bolt right up. Anyone used this before? I have looked for scrap metal in my area, and it is hard to find. The scrappers have all claimed it. I can purchase a piece, but if this bracket will work, then I will use it.
Thanks as always
Thanks as always
