2000 3100 short block purchased with very low miles as a near new take out. Installed the Fiero 2.8 top end and accessories, turbocharged and put it in the car about 5 years ago. Immediately on startup there was a tapping noise that sounded like a loose rocker that I figured out was piston noise right away which would explain why it was removed though hardly used.
I drove the car hard running an average of 7 psi and sometimes well into the high rpm range. Sensing the time was near for replacement given the noise was getting louder and was always annoying I finally removed it from the car in preparation for the 3900 transplant.
I broke the engine down eager to look at the internals to see what effect the turbo had on the engine. The pictures tell the story, GM knew all along pistons # 5 & 6 were a trouble spot, I can't believe they put two different types of pistons in the same engine, pistons 5 & 6 were the only ones that had the antifriction patch and no it wasn't rubbed away on the others.
Nearly all of the pistons had excessive clearance especially # 6 which was probably going to let go any day soon. Despite occassional detonation and high revs the rod bearings looked great, not a hint of copper or the excessive wear that I was use to seeing on 2.8L bearings from a high mileage engine, they looked so unremarkable I didn't bother to pull the main caps.
I'm going to try and link pictures from my FTP site, if I can't get it to work I'll post using standard procedure.
It didn't work, oh well.
The worst of the pistons was # 6 and they are head to head in opposing pairs 1-2, 3-4 and 5-6. Look at the ring gap on number 6 in the bore. It's amazing number 6 was still in one piece, and nearly all of the pistons had excessive bore clearance but 6 was the worst by far.
